Two Questions ??
bronco
01-21-2000 14:13:46
1} What exactly is a AV model Farmall A ? 2} When snow plowing with my SA, the front wheels want to turn and slide sideways rather than to steer straight ahead, when you'r pushing a large pile of snow. why ?My little Cub doesn't even do that!
bill
01-22-2000 05:28:53
 Re: Two Questions ?? in reply to bronco, 01-21-2000 14:13:46
pick up a copy of farmall letter series tractors by guy fay, there is a picture of my av.
The Red
01-22-2000 06:54:05
 Re: Re: Two Questions ?? in reply to bill, 01-22-2000 05:28:53
You will get rich off the royalties! :)
Bill B
01-21-2000 20:29:47
I would guess your plow frame is mounted high on the tractor, and the angle from the pivot point to the cutting edge of the plow is not very perpendicular to the ground. If it is much of an angle, the resistance of the snow will tend to lift the tractor front up, and lessen the traction the front wheels need to steer. When the plow in down, the plow frame should be about level with the ground from the pivot point to the plow. If this is not the case, you could revise the mounting brackets to allow a lower point of pivot, to get the plow frame as close to level as you can.
Red Man
01-21-2000 14:25:14
AV stands for A vegetable. The AV is the hi-crop version of the Farmall A. I can't answer your snow plow question unless it the front end getting light in weight when you are pushing snow. Could be that one rear wheel is heavier than the other one with fluid or weight.
Ludwig
01-22-2000 06:31:24
 Re: Re: Two Questions ?? in reply to Red Man, 01-21-2000 14:25:14
One rear wheel should be heavier since it has a heavier rim to balance the engine being off to the side.
