Anti-freeze in crankcase
Al in Mn
07-25-2006 17:16:46
Just drained the oil in my 43 H which I bought this spring, it ran nice. I opened the plug and ant-freeze came out. Is the head cracked, is it the block or could it be a head gasket? I was going to advertise it but I don't want sell it that way. Used it on the sickle mower and it worked fine. Any coments will be apreciated.
Dave BN
07-25-2006 19:03:39
 Re: Anti-freeze in crankcase in reply to Al in Mn, 07-25-2006 17:16:46
It could be just the O rings at the botom of the sleves leaking, if your lucky.
John M
07-26-2006 03:25:15
 Re: Anti-freeze in crankcase in reply to Dave BN, 07-25-2006 19:03:39
There are no Orings on an H
El Toro
07-25-2006 17:34:37
It could be any one of the 3 things you mentioned.
Pull the head and examine the head gasket for any
blown areas. If the gasket is ok I would have the head magna-fluxed for cracks. Had this problem with a 2.5L GM car. I found heads in the junkyards, but all three of them were cracked too. Had to buy a new head for $500.00 and that's without any valves. Used the old valves had them refaced at a local shop.
You may want to pull the pan and see if you can determine where the coolant is leaking from. It has dry sleeves so I doubt if it's coming from them. You may want to do this before pulling the head. Were you getting any white smoke with the antifreeze smell? Hal
John M
07-25-2006 18:23:21
 Re: Anti-freeze in crankcase in reply to El Toro, 07-25-2006 17:34:37
Block could be cracked on a cylinder wall alowing antifreeze to seep between it and the sleeve.Had that happen once. I would start with teh headgasket.
Al inMn
07-25-2006 19:02:47
 Re: Anti-freeze in crankcase in reply to John M, 07-25-2006 18:23:21
Thanks for the replies
