Super H Carb
bigal18
08-07-2006 20:47:04
Recently rebuilt carb on Super H, however, haveing problems adjusting. Tractor will only start if throttle completly open. Once started tractor sounds like a John Deere. Tractor will throttle down, but throttle is not smooth. The throttle is very limited in adjusting the speed of the tractor. Can adjust mimially, but tractor seems unresponsive. I have checked and the throttle shaft is connected. Do I have a carb adjustment problem or do I have a carb/governor connection problem or is it something else?
old
08-07-2006 21:06:04
 Re: Super H Carb in reply to bigal18, 08-07-2006 20:47:04
A lot of times you have to adjust the govanor to match the carb after rebuilding them. OR you might have the little slot on the govanor to carb in the wrong place either one will cuase some funny problems. I found that out when a friend tried to put his carb back on his 450 and he didn't have the slot lined up right and boy did it runn funny
