Timing-52 Super M
Buck
01-23-2000 16:41:55
I took the distributor with conecting housing off tractor to clean and paint behind it. The rotor was pointing a 7 oclock . Can I put rotor back on 7 oclock and be in correct timing when meshing gears back together at oil fill point. The gears where moved some during cleaning. Thanks for help.
Rick
01-23-2000 17:17:07
 Re: Timing-52 Super M in reply to Buck, 01-23-2000 16:41:55
You should be ok if you did not turn the motor any while cleaning.
Buck
01-24-2000 08:34:11
 Re: Re: Timing-52 Super M in reply to Rick, 01-23-2000 17:17:07
I did not move the motor gears and was hoping it woulld be in time by putting it back the same way. Thanks Rick.. --- Buck
