Distilate or gasoline
ben
01-24-2000 14:33:27
I have a 53 SM. The problem is that the hood has an extra hole on the back of the right side. I assume this is for the starter tank. The problem is it doesn't have a starter tank on it. I need to determine if it is an incorrect hood or it is missing the starter tank. How else can I tell if it is distilate or gasoline?
thanks
-ben
Wardner
01-24-2000 17:03:06
 Re: distilate or gasoline in reply to ben, 01-24-2000 14:33:27
The distillate or kerosene tractors have a different manifold and exhaust pipe. The pipe is cast iron and bolts to the manifold. There is also a tin heat shield that covers nearly all the manifold. All of the distillate and kerosene tractors had shutters. It was optional on the gas.
I think that most of the SM's were gas.
derek
01-06-2001 13:52:43
 Re: Re: distilate or gasoline in reply to Wardner, 01-24-2000 17:03:06
Anyone have the ' formula' for distilate??
jakee
01-24-2000 18:35:33
if it was a original distillate tractor it will have a letter A suffix in the serial number.it real dosent matter run it with gas and you will be happier.
