Order Farmall Cub Parts Online
IH Cub Plow ID???
Brian
01-24-2000 15:50:03
I just purchased a 48 cub, with fron and rear cultivators, sickle bar mower, blade, middle buster and a mounted plow.
However I don't think it is the correct plow for a Cub, it looks too big to me. If anyone can help I'd sure appreciate seeinga picture of a cub with a mounted plow.
BTW this plow has IH512320R1 cast into the beam if that helps ID it.
Pics of the Cub to follow...
Brian
Jim Becker
01-24-2000 20:32:36
 Re: IH Cub Plow ID??? in reply to Brian, 01-24-2000 15:50:03
A picture of your plow would have helped. Anyway, that number is for the beam of a Cub-193 plow. Did you get the depth control lever with it?
Brian
01-25-2000 04:29:18
 Re: Re: IH Cub Plow ID??? in reply to Jim Becker, 01-24-2000 20:32:36
Sorry Jim, will post picture of plow when I can get one took. The implements were stored in the shed to the rear when I took pics.
I did get what I thought was some sort of hand lift. Must be the depth control lever. Geoge Willer sent me a picture from a Cub 193 plow manual. What I have looks like the depth control lever.
Brian with the pics this time!!!
01-24-2000 16:21:26
OK try this link...
Brian
01-24-2000 16:15:58
OK yeser are the pics I promised. Haven't had a chance to make it run yest although I looked at it in this same spot 5 years ago and heard it run then.
