Andy, I may or may not be able to help but need to know: Q1) You mention "regulator" is the tractor equipped with a full fledged 3 terminal (BAT ARM FLD) Voltage Regulator orrrrr rrrrr a simple 2 terminal (BAT GEN) Cutout Relay????? ????? (some have the F terminal also, however) Q2) Is your Light Switch the 4 position L H D B or a light switch ONLY????? ??? (whats normally used if its a VR instead of a Cutout relay) I cant prove this as I have no specs or data nor know the brand or type of your VR Buttttt tt believe on some VR's they are sort of Generic n will work at EITHER Pos or Neg ground buttttt ttt will last longer if used the correct polarity, it has to do with the coatings on the cutout relay contacts. Q3) When the battery runs down is it like a slowwwww ww gradual thing over time or does the ammeter register a heavy discharge when you shut it off (genny can get hot) and then she runs down very fast????? If she registers a heayy discharge on shutdown n the genny gets hot thats a sticking/burned cutout relay contact (regardless in in a VR or the 2 wire cutout relay) Q4) Does it have a working ammeter and whats it show runnig wide open and then when shut down??? i.e. is she charging okay normally????? ? Q5) After the genny was rebuilt, did you Polarize it before starting the tractor??? If the gennys is at opposite polarity from the battery and wasnt polarized correct, it can mess up a VR, maybe thats the problem???? The amp box problem you heard about concerns the L H D B light switches used on the simple 2 wire cutout relay systems cuz on those if the resistor is bad or the switch is bad or dont have a good ground it can cause weak or no charging, thats why we need to know which system you have !!!!! !!! Q6) If theres not a working ammeter do you know if shes charging or not????? Do the lights glow noticeably brighter from idle to wide open????? if you place a voltmeter on the battery n shes charging it ought to rise from 6.3 volts setting to near 7 when running wide open..... From the limited info available I cant tell if shes never charging so the battery eventually just runs down of if she is charging but the VR or cutout relay goes bad????? TRY THIS:::::::::::::::::;; With her running temporarily dead ground the gennys Field post..... see if she charges then or it makes no difference ????? ????? (A) If it charges then BUT NOT OTHERWISE the problem may be the light switch (if a 2 wire relay and a L H D B switch),,,,, ,,or the wires bad from the gennys Field post up to the switch,,,,, ,,,or the switch isnt well grounded. (B) If its a VR, then the problems either the VR is bad,,,,, ,or not well grounded (ground it to the gennys case better),,,,, or the wires bad from the gennys Field post to Fld on VR. I need to know if shes ever charging or not and then if she is charging how long it takes to discharge the battery to help you more. My off the top ideas are shes never charging at all cuz of the light switch (if a 2 wire cutout relay),,,,, ,, or the VR is bad cuz it may not be best suitable for your positive ground (if a 3 wire VR system) ,,,,, ,,or there may be minor issues like poor connectiojns or even a loose beklt or a bad ground either on the VR or genny..... If you wanna work through my Complete Troubleshooting Procedure for non charging post back and I will re post it but its pretty long n complicated so try the field ground tests above n let me know if shes charging n what the ammeter does n easy simple things first like check the VR and genny for a good ground,,,,, ,,,,,tighten the belt,,,,, ,,,check wiring n connections,,,,, ,try n answer my questions above,,,,,and I will try my best to help you more. I kinda wonder if she was Polarized correctly?? cuz that can harm a VR Best wishes n God Bless, lemme know John T
