10 20 clutch and carb
Bill Geer
09-19-2006 21:04:41
Hi Guys Can I get the clutch out with out pulling the engine? I put gas in the tank and opened the valve gas came out ever joint in the carb.I took the carb apart Did not find 1 gasket in it. Where do I find a kit or some gaskets.
Thanks Bill
DonN Ohio
09-20-2006 17:43:25
 Re: 10 20 clutch and carb in reply to Bill Geer, 09-19-2006 21:04:41
Be careful when you put back together. Make sure the grease hose to the throw out bearing is in it's proper place and don't wind it up like I did the first time I started it up. Ended up taking it back apart to fix it. Yes they are a nice running machine. Mine is noisy when it moves in all gears even with new bearings.But I guess I would be too if I had sat in a shed since 1963.
Bill Geer
09-20-2006 08:19:51
Russ It is a 1928.
Cowman would that be Rice equipmemt that I see on here?
Nebraska Cowman
09-20-2006 08:26:50
 Re: 10 20 clutch and carb in reply to Bill Geer, 09-20-2006 08:19:51
yes, email me if you need the number
russ hamm
09-20-2006 05:24:58
bill, cowman is right on the carb. the clutch will come out without pulling the engine. there is a coupler from the output shaft to the transmission input shaft . whenyou remove the bolts this coupler comes out and gives enough room to take out the clutch with the shaft. i have had some that i slid the engine forward though just an inch to make it a little bit easier. what year is your 10-20? great little tractors. russ
Nebraska Cowman
09-20-2006 04:03:40
Excpt for the fuel inlet strainer there are no gaskets in the carb. If fuel is running out it is because the float is bad or the float valve is leaking. Gordon Rice has the new parts.
