10 20 start up
Bill Geer
09-24-2006 15:45:33
I got spark. I got the carb working I think. Now I need some help to adjust the carb.
And maybe some genral starting info. First time I have tryed to bring one of these old dudes back to life.
I think you for any help Bill
Bill Geer
09-25-2006 22:35:50
 Re: 10 20 start up in reply to Bill Geer, 09-24-2006 15:45:33
What I need to know at this point is how to set the carb adjusting screws. It has the brass carb. It has a big one on the top.How many turns out for that one? There is one down low and forward.How maney turns out on this one. I got the tractor a year ago. The man said he ran it about 3 years before that. It has the F-4 mag. I got spark. I did nothing to the motor. But set the valve lash. Thanks for the hslp guys Bill
chuck kaufman Ore.
09-25-2006 17:38:20
when I restarted mine after a long rest I belted it up to another tractor with the plugs out and made sure everything was gettig oil and was nice and loose .put the plugs back in and she started right up look out for a stuck clutch!
russ hamm
09-25-2006 08:43:59
bill, janicholson has covered most of it. a couple of things we should know; did you go through the valves, rings, etc. , or was this a running tractor and you just did the carb? does it have the brass ensign carb? i didn't look through the forum, and you might have talked about this stuff already. does it have the e4a magneto that you have to set the impulse, or does it have an auto impulse that clicks all the time? or does it have the f-4 mag? aren't those a great little tractor? can't hardly pass up ever buying one.
Janicholson
09-24-2006 18:10:28
Be very sure it is not in gear!!!!! !!
When cranking, Place all your fingers and your thumbs (assumes both hands) on the same side of the crank handle on each hand. This prevents them from being ripped off if it kicks back for any reason.
Pull up on the crank only. Do not spin the crank. If it isn't starting when it goes over center, somthing else is wrong, do not try to spin the crank..... Pushing down on the crank puts your face and arm bones in a place of high impact....
Make sure the Mag impulse is working (Snaps when turning crank)
Be sure the mag grounding button is in the non-grounded position (out)
Good luck, JimN
