farmall wide front
bbaro36
10-18-2006 17:35:33
i brought home an h with a factory wide front, i would like to move the front wheels in, they have not been moved in a long time. can anyone let me know what i am getting in too or share any tips? thanks, brian.
Brownie 45
10-18-2006 17:48:32
 Re: farmall wide front in reply to bbaro36, 10-18-2006 17:35:33
Start by soaking telescoping parts & bolts with penetrating oil or your favorite rust buster. If you can get clamp bolts loose, remove them & see if the axles will break loose. Use good blocking under the tractor while working on it. If you weren't trying to get things loose, & were out plowing with the clamp bolts out, the front axle would fall apart in 1 round. Good luck with it.
