SMTA lp?
Atvman
10-21-2006 17:56:04
I found a smta that has been converted from lp to gas. I was wondering if there is anyway to tell (by serial number etc) if it orginally was lp or was initially gas then lp then converted back to gas.
Cotton Picker
10-22-2006 08:02:48
 Re: SMTA lp? in reply to Atvman, 10-21-2006 17:56:04
The SMTA"s on "factory" lp were converted in Lubbock, Texas for Harvester Co. I have been told there were around 500 made this way. The tank is looks somewhat different, lower and longer than ones I have seen that were converted in the field.
If you can provide a picture some people who know more than I do can help you out.
That is my 2-cents worth.
CNKS
10-21-2006 20:06:19
Engine and/or chassis suffixes of C or N indicate original LPG engines. I do not know if these letters were used on all factory LPG tractors, though.
D Slater
10-21-2006 19:47:09
Don't think there's anyway to tell 100% for sure by serial # since none came dirrect from IH as LP. One clue is that some sent to be converted have is letter D or E following engine and tractor serial numbers.They were equiped with high alltitude pistons for higher compression with the LP gas. Not a 100% sure way though because gasoline tractors could be that way to.
Farmall Mann
10-21-2006 18:18:21
Serial # shoud indicate original factory fuel,probably gas converted to LP ,then back to gas,just my guess FM
Atvman
10-21-2006 18:24:09
 Re: SMTA lp? in reply to Farmall Mann, 10-21-2006 18:18:21
Anyone know how to check the serial number?
Farmall Mann
10-24-2006 19:11:46
 Re: SMTA lp? in reply to Atvman, 10-21-2006 18:24:09
Suffix letter code following # on engine block C LP gas burning attachment N LP gas burning attachment (high altitude) The same letters shoud follow tractor serial # GOOD LUCK Farmall Mann
