injectors
billde
10-24-2006 18:44:53
Can someone tell me if the injectors in a 560 are the same as the ones in a 660? I know there is an early and late style for the 660, but don't know if I can substitute a 560 injector for a 660 injector.
Wardner
10-24-2006 19:27:01
 Re: injectors in reply to billde, 10-24-2006 18:44:53
There is no differentiation on injectors (IH calls them nozzels) in the parts book. The pumps are different. Different probably only in fuel delivery and governor settings. This gives the 660 twenty more HP.
billde
10-25-2006 06:08:41
 Re: injectors in reply to Wardner, 10-24-2006 19:27:01
Can you tell me the serial break on the new style/old style?
Wardner
10-25-2006 09:29:37
 Re: injectors in reply to billde, 10-25-2006 06:08:41
The nozzle numbers below refer to the engine number, not the serial number of the tractor.
297 263 R91 NOZZLE ASSEMBLY, injection (6)
D-282 501 to 24414
(order 332 495 R91
332 495 R91 NOZZLE ASSEMBLY, injection (6)
D-282 24415 up
Apparently the early style is discontinued and replaced by the later style.
I was wrong about different injection pumps for 560 and 660. The same pump is listed for both tractors. There is an early and late pump. The early is also discontinued and replaced by the later.
Break comes at tractor number 26600 for 560 and 26055 for 660
