International 350D utility
Brenden
10-25-2006 02:54:12
I'm trying to find a water pump for this diesel tractor and having trouble.The pump I took off has a keyed shaft that is threaded at the end to hold the pulley on and the only replacement I can find has a pressed on pulley.They wont take my pump as a core because its not what they are sending me.I thought I could rebuild this one but the shaft is junk.Also you have to remove the pulley before the pump because it blocks the bolt holes in the pump so how do you press the pulley on after pump is installed.Any help is appreciated-Thanks Brenden
Tractor Dan
10-25-2006 14:40:54
 Re: International 350D utility in reply to Brenden, 10-25-2006 02:54:12
i think there is one on ebay right now
Bill46
10-25-2006 05:16:03
I took someone's advice on here and went to the MF dealership and they matched one up for me. Continental used the same water pump on a number of engines. You may have to put shims under the radiator...I had to raise mine about a 1/2".
Good luck.
