clutch does not disengage
bogus
10-28-2006 17:56:32
while using my international 444 the clutch decided not to disengage from the transmission when i pushed down on the peddle....any possible solutions??
gene bender
10-29-2006 02:00:37
 Re: clutch does not disengage in reply to bogus, 10-28-2006 17:56:32
Too many things could have happened. Split the tractor then you can fix what is wrong
JayWalt
10-28-2006 21:03:17
A bit of thread hijacking here, but what all can be done to the clutch without splitting the tractor?
Michael Soldan
10-29-2006 04:47:52
 Re: clutch does not disengage in reply to JayWalt, 10-28-2006 21:03:17
Jay Walt, most I-H tractors had an inspection pan on the bottom, so you could adjust clutch fingers, inspect for wear and even change the clutch plate. An H can have a clutch change without splitting the tractor. You should be able to get at most yoke and throw out bearing assemblies...Mike in Exeter Ontario
Michael Soldan
10-28-2006 20:30:21
It sounds like a throw out bearing problem. I had one go when the yoke that holds the throw out bearing(a mica disc) broke off one side, the shaft that holds the yoke was badly worn. If I have the correct tractor , you should be able to remove a pan underneath and access the shaft and bearing. I got all the parts used for $60 and it has worked fine since. This was on a B250 which is alike to the 444, I believe. get underneath, get the inspection pan off and you will know right away. It is a simple job to remove that pan.
Sheepdog in NE
10-28-2006 19:49:42
Not sure what type of disc is in it but if the pad comes off it can wedge in there and not let the disc stop turning. Also a broken spring can do the same thing as it falls out of it's place in the disc.
Ken L.
10-28-2006 19:08:48
Could be the the throwout bearing went out or the fingers wore off the pressure plate.
James Babcock
10-29-2006 07:16:28
 Re: clutch does not disengage in reply to Ken L., 10-28-2006 19:08:48
Had a similar thing happen on a B175, it turns out that water had gotten in there while it was parked outside, and the clutch disc had "rusted" to the flywheel. Can't remember exactly how I got 'er loose but I think I wired the pedal all the way down, took off the inspection plate, and pried the disc loose with a big screwdriver or crowbar. Luckily, this hasn't happened again.
James Babcock
10-29-2006 07:18:48
 Re: clutch does not disengage in reply to James Babcock, 10-29-2006 07:16:28
Oops, I'm sorry I missed the fact that you were using the tractor when it happened. My reply above is probably not applicable to your situation.
