M HEAD??????????????
BAXTER
11-27-2006 13:46:11
i bought head that i thaught was 4 an M.. but wh ni put my old vale train on the new head it didint fit not big enough. So i got both numbers the 1st number was off the head out side of the vale cover it was10 22 w..the second numbers were under the vale cover they were...8060-DB.. i was wondering if any body whould no what this head was too.Thanks in advance
RustyFarmall
11-27-2006 13:56:11
 Re: M HEAD?????????????? in reply to BAXTER, 11-27-2006 13:46:11
8060 is a high compression gasoline head. The other number you mentioned is a casting code, and tells us nothing except for when it was made. The other head is probably the low compression kerosene or distillate head, and the valves will NOT interchange between the two.
