Electrical
Bill Pingel
11-30-2006 06:23:58
Are all c"s & H"s positive ground? If not when did they change? Is the C & H wiring diagram, for the generator, the same? Thanks Bill
Rustyfarmall
11-30-2006 06:37:32
 Re: Electrical in reply to Bill Pingel, 11-30-2006 06:23:58
Pretty much everything that had a six volt battery was positive ground. There are some exceptions, but just about all of the older tractors were positve ground. Farmall As, Bs, Cs, Hs, and Ms as well as the other makes.
El Toro
11-30-2006 06:34:13
All the C's and H's were positve grounded with 6 volt system. So were most american cars and trucks. My first 12 volt car was a 57 Chevy. I don't think there's much difference in the wiring
except some of the early tractors may have had cutouts and the later with regulators. Hal
Allan In NE
11-30-2006 06:37:45
 Re: Electrical in reply to El Toro, 11-30-2006 06:34:13
YEs SIr,
Chevy swapped owver in 1955 and IH did the change during the 450 run.
Allan
El Toro
11-30-2006 07:09:15
 Re: Electrical in reply to Allan In NE, 11-30-2006 06:37:45
Hi Allan, How's that weather out your way? Very mild here in MD, but that's going to change by the weekend. Looks like KS and MO are getting some winter weather. Those 283 engines were known for losing cam lobes. I don't know if the 265cid engine had that problem. Ford had the same problem with their 1954 V8's. Hal
