Order Farmall Cub Parts Online
Farmall Cub Bolt Pattern Rim Question
AC Power
12-05-2006 17:28:20
I would like to know the bolt pattern for a farmall cub. I need to know how much it measures between bolt holes that are beside on another and across from one another. And also, will farmall super A rims bolt on a cub wheel center?
What im trying to do is figure out is if Cub wheel centers will bolt to a Allis Chalmers C hub. I know the bolt pattern is probally different, but if it is kinda close i can make it work because i am a machinist. Im tryiny to get my AC C light enough to pull in the 2,000lb class, then if its possible i wud like to put farmall super A rims on the cub centers so i can run my 11.2-24in. tires.
So its 2 main questions. the bolt pattern for the 5 lugs bolts, and if super A rims will go on cun centers. thanks a bunch, jason
