Farmall 450 gas tank removal
Alan in VA
12-08-2006 05:02:20
I can't get the gas tank off of my 450 for anything. All the stuff that seemed removable around it is now off, but no luck. It looks like to me that I will need to remove a power steering hose on the left side. Does anyone know if this is likely, and if it would be opening a real can of worms? I know just enough to be dangerous.
Any help would be greatly appreciated.
Alan
Nat 2
12-08-2006 11:57:53
 Re: Farmall 450 gas tank removal in reply to Alan in VA, 12-08-2006 05:02:20
We did the gas tank on my father's 400 last summer because the neck on its original tank came unsoldered and fell in. Local guy gave him a complete tank so we changed it rather than having the existing one fixed. He plans on having it fixed some day, maybe putting it back in.
It was a tight fit, but with the right wiggling and prying gently against some hydraulic lines, we popped it out.
D Slater
12-08-2006 05:22:59
It will come out the left side but its a tight fit. If you need to remove the power steering hose it won't cause much problem. Little bit of oil will come out,just keep dirt out and raise end of hose higher than steering to keep oil from running back out of the hose. When hooking back up as long as complete hydraulic system was not drained it will blead air out buy turning steering from lock to lock several times.
