ChadS
12-17-2006 11:25:58
Re: ChadS in reply to Brian in Ne, 12-17-2006 08:59:14
We got a Super H thats bout like that,,,, We happend to find a set of M&W high domed pistons and put in it. Worked out great!! Still way too much power for low gear,, even at 5000lbs,,, with 14.9X38 tires. We actually detuned it and that helped it out quite a bit. Thats our div 1 puller,,,,, then we have another H a 52 model,, has IH 6 cyl pistons with a 1 inch stroke for 3500-5500 div 2-3 classes,,, solid 2nd and 3rd gear tractor,,, pulls real well,,, but not like the third H I have,,, I did drop the nose down to where my front tires are almost rubbing the frame rails,,, I run that H from 3500- whatever I wanted to throw on it, (that my back allowed me to do) LOL! Div 3,4 and 5 classes. Solid 4th gear tractor up to 5000lbs. The block puked, so ive been 3 years redoing the design so it dont happen again. I used weld on hubs for the rear, Ih baler front rims, and IH wagon hubs for the front,,, 6 bolt, with 4.00X15 tri rib tires. Has a rake to it,,, but it looks good and not so slanted down it looks bad,,, with me on it empty is 3200, but its all cast iron still. Chad
