Farmall M, wet or dry sleeves?
Brian J
12-21-2006 16:10:04
After looking the other way and griting my teeth from watching it sit outside for 6 years. I finally towed my uncles once beautiful M to my place to get it running for him to sell. Water poured from several spark plugs when I pulled them out. Manifolds and carb were filled with water also. There is a hole/split in no. 4 cylinder wall leading to water jacket. My thinking is that if it has wet sleves there is a better chance the block my be salvagable but I dont know what type it has. What do you guys think about the situation? Thanks in advance for your input and experience.
NDS
12-22-2006 10:13:45
 Re: Farmall M, wet or dry sleeves? in reply to Brian J, 12-21-2006 16:10:04
If tractor does not look good (above average) you will be lucky to get price of engine overhaul for it after it is running.
glennster
12-22-2006 06:44:39
you can have the block welded and then machine the block back to fit the sleeve. then use a little loc-tite on the top and bottom of the sleeve when you install the new one.
Eric W
12-21-2006 19:46:46
Block is probably busted. Where are you located, want to sell it as is ?
Brian J
12-22-2006 05:59:20
 Re: Farmall M, wet or dry sleeves? in reply to Eric W, 12-21-2006 19:46:46
S.E. Mich., I'll have to talk to my Uncle and see what he wants to do.
Keith-OR
12-21-2006 20:13:19
Eric, looks like he is around Pasadena, CA
John M
12-21-2006 18:28:56
Dry Sleeves, the water probably came from rain sitting out for 6 years.The water probably froze and cracked the block.
Brian J
12-21-2006 17:33:29
Ouch!!
Tom Windsor
12-21-2006 16:14:20
I am not sure about M but H has dry sleeves--I suspect that M does also. Some of the other guys will let you know for sure. If the water is coming out where you say, get ready for heartache! I was wondering if it would durn over?
Andrew Z
12-21-2006 16:16:52
 Re: Farmall M, wet or dry sleeves? in reply to Tom Windsor, 12-21-2006 16:14:20
yep, The M has dry sleeves.
Andrew
