closed center pump
1466 go
12-27-2006 19:29:48
has anyone mounted a closed center pump on an ih for a bale bandit
Nat 2
12-28-2006 05:19:39
 Re: closed center pump in reply to 1466 go, 12-27-2006 19:29:48
Assuming that this "bale bandit" (???) is hydraulically-driven, there is only one place you can mount the pump that will be able to transmit enough power to run the unit. That would be on the PTO.
If the hydraulic system on this "bale bandit" is self-contained, and the pump mounts to the PTO, what difference would it make whether you mounted it on an IH, JD, Oliver, or any other tractor with enough horsepower to run it? A PTO is a PTO on most any tractor made from about 1941 on. 1-3/8" 6-spline shaft, 540RPM. It's standard.
