Biggest Farmall-just curious
AGEN
02-03-2000 20:17:41
I saw a beautiful picture of a Farmall 1206 posted not to long ago. What is the horse power of a 1206. And for my own curiousity, what is the biggest tractor (model and h.p. if you know it) that IH made with the "Farmall" name on it. Thanks guys.
mark
02-19-2002 13:41:08
 Re: Biggest Farmall-just curious in reply to AGEN, 02-03-2000 20:17:41
just curious where you found the picture of the 1206 at. could you give me the adress please
Aaron
02-04-2000 08:35:01
Can't remember if it said Farmall on the side, but the biggest they ever made was the 4568. Made for them by Steiger. HAd a 700 CI V-8 and probably close to 300 horse. We ran one for a while. That was a machine and a half. Think the last that said Farmall was the 1456 maybe? Be around 120 or 130 horse.
Aaron
19 Reds
02-06-2000 17:43:43
 Re: Re: Biggest Farmall-just curious in reply to Aaron, 02-04-2000 08:35:01
We've got 2 4586's. They've got 800 (798) cu in engines rated at 300 hp. Also made at the same time were 4786's which used the same motor but were rated at 350 hp. The 45's are quite a machine for their age (late 70's - early 80's) we pull a 9 bottom plow and 27' field cultivator with roller behind with them. They like thier fuel (15 gal hr).
Mudcat49
02-04-2000 07:16:43
IHC made 1566's and 1586's and don't forget the classic 1468!!!
p
02-04-2000 09:25:18
 Re: Re: Biggest Farmall-just curious in reply to Mudcat49, 02-04-2000 07:16:43
1468 - man I have only seen one of them, except for toy collection. neet concept but too bad it was a flop!
HAYBALER
02-04-2000 10:51:28
 Re: Re: Re: Biggest Farmall-just curious in reply to p, 02-04-2000 09:25:18
1468 WAS THAT THE ONE WITH THE V-8 ENGINE?
p
02-04-2000 10:54:52
 Re: Re: Re: Re: Biggest Farmall-just curious in reply to HAYBALER, 02-04-2000 10:51:28
Yes!
100Glenn
02-04-2000 09:29:05
I'm kinda partial to the 7488 myself, even though it isn't a Farmall... that's one tough-looking machine. Too bad it got canned when Tenneco took over the ag division.
Theman
02-04-2000 05:43:36
The biggest Farmall I've seen in this part of East Texas was a 1486. It was at an auction and it was too big to fit through the door. They pulled the front end inside and filled the room with smoky exhaust (cold engine). It sold for $10,000 to an auction outfit in Oklahoma (Brinkley). That Farmall had my nomination for the biggest tractor in the county.
David Saville
02-04-2000 20:26:45
 Re: Re: Biggest Farmall-just curious in reply to Theman, 02-04-2000 05:43:36
The last series to carry the Farmall name was the 66 series. That makes the 1566 the largest to be called a Farmall. The name was gone by the time the 86's were built.
medfarm
02-04-2000 22:43:07
 Re: Re: Re: Biggest Farmall-just curious in reply to David Saville, 02-04-2000 20:26:45
My 1566 has Farmall on the small model emblem near the radiator. The model year is either 1976 or 1977. Horsepower is around 160 depending on the injector pump setup. Since the 66 series tractors had the fuel tank (45 gal) over the hood, this tractor can not run 8 hours pulling a 18' offset disc. I use 18.4-38 duals for pulling the heavy tillage equipment. After an engine and differential rebuild 3 years ago, the old work horse should be around our farm for many more years.
Brian
02-04-2000 20:45:07
What about the 1568,and the 4166 and 4366 4x4's?
Brian
02-04-2000 20:42:16
112.64 pto hp
02-04-2000 04:40:29
for the 1206
