1st 4386- one owner coming up on auction
bshannon
01-04-2007 06:53:42
third party image
Found this auction notice for Jan 11th, wonder how much this will bring?
IH 4386, 20.8 x 38 w/duals, 3 pt., 3 hyd. outlets, serial #is 501 - the first one, one owner w/1,500 hrs. on new engine
GordoSD
01-04-2007 18:34:08
 Re: 1st 4386- one owner coming up on auction in reply to bshannon, 01-04-2007 06:53:42
Looks like 4000 dollars in rubber there.
Gordo
Matt in ND
01-04-2007 14:14:22
I wouldn"t think it would bring much over $10,000. I have seen them go for a lot less, usually in the 6 mark. They are too small for any serious work around here. Also, the hyd. pump isn"t big enough to run many implements, mainly an air seeder. No power shift. They also are a Steiger painted red, made by the Steiger company for IH. Parts are interchangable with the old Steigers.
Bob
01-04-2007 18:42:59
 Re: 1st 4386- one owner coming up on auction in reply to Matt in ND, 01-04-2007 14:14:22
Matt,
There's a LOT of IH in the powertrain of that thing that was NOT used in the puke green steigers of the time.
It is NOT a steiger painted red, although it WAS assembled at Fargo.
Look at the IH "rear end" used as the front axle in the photo.
NO steiger Clark or whatever the heck front axle steiger used at the time under there!
RustyFarmall
01-04-2007 10:35:10
If it was green it would easily fetch about $90,000, but since it is RED, and the fact that it is ALL THERE, it should go over $100,000.
JayWalt
01-04-2007 08:43:03
That thing is a beast!!
I'd hate to get ran over by that, must be at leaat 10ton.
I've say at LEAST 15,000, probably more and I know nothing about tractor pricing. Those were around 100,000 new, werent they?
The Dukester
01-05-2007 10:12:44
 Re: 1st 4386- one owner coming up on auction in reply to JayWalt, 01-04-2007 08:43:03
That tractor was priced at $42,500 for the basic standard equipped tractor...duals and other stuff was a little extra. They weighed from 20 to 25 thousand pounds. This model had the good DT466 engine, the biger ones had the not-so-good IH V8 diesels.
