1941 Farmall A Question
Old Bob
01-05-2007 06:22:42
Howdy, I just came into a 1941 Farmall A. It runs fine, but I"m going through it to clean things up. There is a fill cap in front of the mount for the distributor. I have no idea what this would be. Also, the original temp. gauge is in good shape, but the connecting wire is broken about a foot away from the gauge. Can I repair this wire some how, or remove it from the gauge, and replace it with the wire comung from the sending unit? I would GREATLY appreciate any help You could give me. Happy New Year, Grizz
TomPW
01-05-2007 15:53:32
 Re: 1941 Farmall A Question in reply to Old Bob, 01-05-2007 06:22:42
I Have a 1952 Super AV in original condition. There is no heat gauge on it at all.
HENRY E NC
01-05-2007 14:13:25
I am in the process of rebuilding a 1941 A. The temp guage sits in front of the distributer and there is no fill in that area. If the wire to the guage is broken get a whole new one from this site. WQhat is your serial number founf on plate on left side of tractor under the seat. That will tell you what you have for sure.
HENRY E NC
01-05-2007 14:13:02
MattofVinings
01-05-2007 10:12:32
Bob, I was unable to get the links you posted to work correctly.
Bob
01-05-2007 13:12:08
 Re: 1941 Farmall A Question in reply to MattofVinings, 01-05-2007 10:12:32
Sorry, Matt!
The "hotlink" that was posted SHOULD work, I also posted it as text that could be "cut and Pasted" into a browser, since some sites do not "take" as hotlinks on this site.
The ":" was missing out after the "http" in the text version of the link.
Link
CNKS
01-05-2007 07:32:58
As stated below, you have an H or M, or some other tractor in that series. If the gauge has a wire, it is an aftermarket gauge that is somehow wired into the electrical system. As noted, about any temperature gauge thru at least the 60 series is mechanical and not repairable -- I have a 460 with a mechanical gauge. There are "inexpensive" replacement gauges readily available from several sources.
Bob
01-05-2007 07:11:17
 How to repair a heat gauge in reply to Old Bob, 01-05-2007 06:22:42
Hobbyists apparently repair these things themselves!
If you are comfortable doing it, you could save an original gauge.
Here's a link to a webpage of someone who has, with a link to another resorce that he recommends as even better:
Link
Bob
01-05-2007 07:11:16
Link
Bob
01-05-2007 07:11:14
Link
Roger Mills
01-05-2007 06:37:10
If it is a '41 A it was a mechanical temp gauge, not electric and the "wire" is a thin tube from an expansion bulb. If it is broken or crushed it must be professionally rebuilt or replaced as a unit. They are filled with a liquid that expands when heated and the gauge is actually a pressure gauge that reacts to the expanding liquid. Today they use a blend of freons to calibrate the scale and are not adjustable in the field.
Andrew Z
01-05-2007 06:33:01
Are you shure you have an A there cause I have a 45 A and there is no fill cap in front of the Mag/Dis. the engine oil is added in the top cap (above the hood). Do you have some type of Hydro systme on it?
Andrew
City-Boy McCoy
01-05-2007 10:19:29
 Re: 1941 Farmall A Question in reply to Andrew Z , 01-05-2007 06:33:01
Sounds like maybe the A has a newer engine - like maybe from a 140...? mike
glennster
01-05-2007 06:31:43
are you shure its a farmall a? sounds more like an h or an m. i dont think the a had a temp gauge, and the c-113 motor had the oil fill thru the hood into the valve cover. the temp gause should be mechanical, if the cable is broken , you need to replace the whole gause assembly. go to galleries on the left, click on tractor photos and search for farmall a , see if its your tractor.
