400 diesel injection pump
Berry450d
01-10-2007 07:51:53
On the side of pump there is over flow pipe when this tractor is not running a steady stream of fuel runs out of it,unless you turn fuel off at tank. Starts and runs good other than that. I am sure this is not normal. Any ideas about fixing this,or will I need to send pump to have fixed. Thanks for any advice.
Berry450d
01-10-2007 10:34:15
 Re: 400 diesel injection pump in reply to Berry450d, 01-10-2007 07:51:53
Thanks Ron,I thought maybe it was along them lines ,but this is the first one I ever had to leak like this. Greg
Ron in Nebr
01-10-2007 10:19:54
The seal on your transfer pump is bad. Go over to the Red Power site and do a search, both on general IH and construction equipment both(TD-6 crawler used basically the same engine).
They have lots of info on part numbers and how to replace the seal. It's a simple job, the main pump stays on the engine.
Berry450d
01-10-2007 14:38:50
 Re: 400 diesel injection pump in reply to Ron in Nebr, 01-10-2007 10:19:54
Ron I couldnt find the right place to hunt the info on this pump.
Ron in Nebr
01-10-2007 15:52:43
 Re: 400 diesel injection pump in reply to Berry450d, 01-10-2007 14:38:50
(hope this is ok to put here) Do a search on yahoo for "red power magazine forum". That should get you there.
