M hydraulics
Berry450d
01-10-2007 14:34:11
I have a 1950 Farmall M,serial number is 223833X1F I want to know if a live hydraulic pump from a 400 will fit this.
Berry450d
01-10-2007 15:50:40
 Re: M hydraulics in reply to Berry450d, 01-10-2007 14:34:11
I new they changed in mid 50 sometime, I just dont now were my tractor falls in at.
D Slater
01-10-2007 16:04:17
 Re: M hydraulics in reply to Berry450d, 01-10-2007 15:50:40
Your to low but who knows for sure after all these years. Its hard to do on tractor but if you can see numbers on cover and it has a 4 didgit # with suffix thats a early cover. Late is 6 didgit with R?.
Berry450d
01-10-2007 16:38:48
 Re: M hydraulics in reply to D Slater, 01-10-2007 16:04:17
Thanks for info,I will go look and see if I can see the numbers. Thanks to all
Janicholson
01-10-2007 15:30:59
YOur tractor falls in the middle of 1950 production, I do not have a parts book at hand, so it could go either way. If the bolt hole spacing is correct, it will. they are off by about a half a bolt hole, so measure carefully. JimN
