42 H Carb Problem
BDE
01-10-2007 20:18:38
When I turn on the gas at the sediment bowl and don't crank up right away I get gas running out of the carb. When I crank up the gas stops leaking out of the carb. On uphill or downhill grades she starts running rough with lots of black smoke. Is this a float level problem or a sticking float.
Thanks for You help.
Janicholson
01-10-2007 20:39:42
 Re: 42 H Carb Problem in reply to BDE, 01-10-2007 20:18:38
Yes. It is either a needle and seat with a groove worn in it, not allowing full shutoff, or it has a sticking or sinking float. The float can be soldered. See soldering floats in the archives for info. JimN
