Belt pulley ?????
Bryce
01-19-2007 12:11:16
I have a belt pulley that is 15x9,the surface is I guess what I would paper.I have been told it was off of a 560 by one person and off of a W6 or W9 by another.Can anyone tell me what I do indeed have? Thank you.
Fancy Farm
01-19-2007 19:55:36
 Re: Belt pulley ????? in reply to Bryce, 01-19-2007 12:11:16
I don't want to start a fight but the size o the pulley means it was used for an application that needed higher belt speed. I just posted a picture of a 52 SM with a 15 inch paper pulley that is belted to a 1936 stover hammermill. The hammermill instructions have a chart for correct pulley size and it calls for a 15 inch. This tractor pulled this mill for years after it was bought new. The larger pulleys were also used for silage blowers.The picture is in tractor photos. By the way I had the pulley restord by paperpulleys in Nashville and the part numbers were correct.
chuck46
01-19-2007 20:18:06
 Re: Belt pulley ????? in reply to Fancy Farm, 01-19-2007 19:55:36
My uncle had his old IH blower running so fast we were all afraid of it. Finaly did blow it up, almost killed his boy.
chuck46
01-19-2007 16:07:14
Hi, Your pulley is not off an H,M,W9 or any of the newer series of them. They had a 10, 11, and 13 inch diameter respectively. They mount with a 4 bolt patern, 3inch center hole and 4 !/4 inch accross the bolt holes. It could possibly be from a 15-30, 22-36 or W40, I don't know any of their specs. My other guess would be an implement of some kind, like a thresh machine, silage blower or any of a hundred and some others. Good Luck, Chuck
randy hall
01-19-2007 16:27:50
 Re: Belt pulley ????? in reply to chuck46, 01-19-2007 16:07:14
hi chuck i hate to blow you out of the water on this one but the 9 series parts book lists 8 1/2", 9 3/4", 11", 12", 13", 15".16 1/2", 18" and 19 1/2" belt pullies for these tractors
randy hall
01-19-2007 16:29:40
 Re: Belt pulley ????? in reply to randy hall, 01-19-2007 16:27:50
i forgot to add the standard pulley for a w-9, 14".
randy hall
01-19-2007 12:43:57
this large of diameter would be for the w-9 series tractors. are you wanting to sell it?
Bryce
01-20-2007 06:11:54
 Re: Belt pulley ????? in reply to randy hall, 01-19-2007 12:43:57
Yes I do want to sell it but I have a gentleman in NY that has first chance at it as I told him it was for a 560.I dont know if he will still want it or not,if not i"ll let you know.Thank you for the help.
chuck46
01-19-2007 19:27:21
Hi Randy, Sorry I hate to give anyone wrong information, glad you are able to correct it. Going by what our tractors came with. Boy if you put that 19inch on an H you could really wind something up. Thanks, Chuck
