Seat
Allan In NE
01-22-2007 02:27:01
Has anyone priced a seat suspension from mother CaseIH lately? Or, know of another vendor?
Got one that the bushings are loose, but it has already been "tack welded" once.
Almost scared to call 'em. :>(
Allan
John A.
01-22-2007 21:14:34
 Re: Seat in reply to Allan In NE, 01-22-2007 02:27:01
Allan, Well my phone lines have been down, since yesterday afternoon, or I would ave respoded sooner!
I bought a set of aftermarket seat bushings the other day for my 966. They were $30 EACH!! Mother IH wants over $70 EACH! Ouch either way!!!. My local IH dealer carried the aftermarket bushings, so it wasn't ard to get them. Its the different steel parts that worry me, for mine as a bunch of slack in some of them. Anywayyyyy.
Later,
John A.
DADDY E
01-22-2007 19:57:39
Wow. After all the imfo. you have passed on I think I can help you this one time anyway.
I re-built the seat on a IH 574 [it's the scissor type action with a small shock between the scissors]. Sounds like yours is the same.
I removed the whole seat assemby ground off the tack welds to remove the pins [I think they were made that way from the factory] You can get all the bushings from Case-IH. I replaced the shock [wore right out] re-assembled and re welded the pins as they were.They were plastic bushings in mine, I bought the two large ones that fit around the main tube and made the ones that fit on the pins but they wern't too expensive from the dealer. I also replaced the cushioned seat. Most of my trouble was getting the seat assembly off the tractor. The adjuster was seized and I had to adjust it both forward and back to access the screws. Now it's as good as new. Hope this helps on your tractor.. Eldon from Ont.
El Toro
01-22-2007 08:09:26
Can you have new bushings made at your local machine shop? Hal
PS:I would keep that seat too.
Allan In NE
01-22-2007 08:35:58
 Re: Seat in reply to El Toro, 01-22-2007 08:09:26
Oh,
Starter bushings fit right in the thing. Like I say, it's been "tacked" before tho.
Allan
Janicholson
01-22-2007 06:46:57
Allen,
If the old one is still off the machine, Maybe you could remove the "organic" parts and braze weld the bushings back into the frame. US Seat company makes commercial seat systems, How about an air ride from a bent simi tractor. JimN
Allan In NE
01-22-2007 06:59:06
 Re: Seat in reply to Janicholson, 01-22-2007 06:46:57
Oh, I dunno,
I'm kind of fussy 'bout keeping them more or less original. Think it is just the "old man" in me. :>)
Allan
third party image
Al L. in Wisc.
01-22-2007 20:14:39
 Re: Seat in reply to Allan In NE, 01-22-2007 06:59:06
Looks to me that tractor has a nice place to live - fancy windows in the garage door and all. Have you got it that nice? P.S. remember to concentrate your urine tonight, ok??
Don L C
01-22-2007 08:49:29
Allen'
You gotta good looken seat there..... look it over decide why they welded on it..... .build that pice stronger..... do a good job.....paint it the correct color....install new rubber buishings and look at all the money you saved..Don
Janicholson
01-22-2007 08:45:47
Or in the case of Sound deadening a little bit better. Looking very good. That cab will be so well outfitted and quiet that your gauges will be used tell if it is running:-) JimN
Allan In NE
01-22-2007 09:11:22
 Re: Seat in reply to Janicholson, 01-22-2007 08:45:47
Pretty sure I've got it water tight so far. :>)
Allan
cannonball
01-22-2007 06:21:59
Allen have you looked at
Link
MAY GOD BLESS THE USA
No tools
01-22-2007 04:46:45
Allan ck this out www.the-co.com
part number 379319rh
Bill
Al L. in Wisc.
01-22-2007 06:09:19
 Re: Seat in reply to No tools, 01-22-2007 04:46:45
When I did the c/p action, a message stated no item matched this number? I also saved the website and plan to go back and check out the "links". Just previewed this page. Allan, cast iron seats aren"t bringing the high price they did several years back.
RustyFarmall
01-22-2007 05:22:50
I went to that website, copied and pasted the part number into the search box. I learned the price, and I learned that part number is for a suspension, but I have no idea of the application.
Allan In NE
01-22-2007 05:41:03
 Re: Seat in reply to RustyFarmall, 01-22-2007 05:22:50
Rusty,
An upper suspension is that scissor-acting mechanism for vertical movement seats that the row crop tractors use. Think they are all the same 06, 56, 66 thru 86 series tractors.
Thanks Bill, I appreciate it.
Allan
RustyFarmall
01-22-2007 06:01:06
 Re: Seat in reply to Allan In NE, 01-22-2007 05:41:03
Yeah, I figured that, but by entering the part# into the search box, it should come back with a full description of the tractors that it fits, and it didn't do that.
No tools
01-22-2007 05:40:43
don't know what to tell you but the last one is on my 1066 international tractor.
Al L. in Wisc.
01-22-2007 04:35:50
Allan, as I check the time, "ya ain"t concentrating your urine!" Now, what big number tractor is ya looking to getcha a seat for? Why not put an old cast iron seat on. In the cold Wisc. winters, my uncle would lay a gunny sack on the cold iron.
sd pete
01-22-2007 05:45:35
 Re: Seat in reply to Al L. in Wisc., 01-22-2007 04:35:50
Has anyone on here ever checked out an air ride seat
Allan In NE
01-22-2007 06:00:32
 Re: Seat in reply to sd pete, 01-22-2007 05:45:35
Too spendy for my blood. Think they start at around $600?
Allan
Jim Johnson
01-22-2007 09:21:17
 Re: Seat in reply to Allan In NE, 01-22-2007 06:00:32
Allan you can get a good one in the $300.00 range for a semi but I know that isn't what you want. Jim
sd pete
01-22-2007 06:38:52
guess this old bucket wont get one then either
