Tractor governor
Tina Garcia
01-30-2007 16:24:58
Have problem with tractor backfiring when you put the trottle down. Someone at the parts store said it is probably the governor? If so I am looking for a rebuilt governor for a 460 Gas International Tractor. Any help would be appreciated.
Janicholson
01-30-2007 18:33:14
 Re: Tractor governor in reply to Tina Garcia, 01-30-2007 16:24:58
Tina,
I do not know how long you have had this tractor, Farmalls backfire on deceleration. If it was a modern car (or some new tractors) it would have a anti backfire valve, or a decel valve controlling the fuel injection shutoff. I recommend checking the richness of the Idle mixture. If it is too rich it will allow excessive backfire. Some is normal. If it changed radically then a bad distributor, or other issues may be present. JimN
Bob
01-30-2007 19:26:51
 Re: Tractor governor in reply to Janicholson, 01-30-2007 18:33:14
Don't forget, a cracked exhaust manifold or blown exhaust gasket can
cause "fackfiring" 'cause of air being admitted to the HOT exhaust mixture.
Janicholson
01-30-2007 19:44:52
 Re: Tractor governor in reply to Bob, 01-30-2007 19:26:51
true, but loud. JimN
AOOC
01-31-2007 08:45:32
 Re: Tractor governor in reply to Janicholson, 01-30-2007 19:44:52
Been my expierence to pretty much know what you need before you start buying parts. points and timing sounds like a safe bet to start with.
Bob
01-30-2007 19:43:18
 FACKFIRING??? in reply to Bob, 01-30-2007 19:26:51
"FACKFIRING???"
Just SHOOT me!
James Williams
01-30-2007 18:14:41
Tina,Just my experence,any time there is back firing its usally in the points
Allan In NE
01-30-2007 17:45:41
Yep,
Somebody at the parts store doesn't know what he/she is talking about. :>)
Allan
Ken B.
01-30-2007 16:40:14
I would look at the timeing, points, plugs and the fuel system before I went to governor for backfireing . Might think about changing part stores also. Just my 2 cent. Ken B
