1940 Farmall A ?? cable to mag
Brad in WA
01-30-2007 19:51:31
anyone have pics of the setup on early A's where the switch cable and mag mount? For our restoration. What holds the cable in the middle? How is the set up fastened? to what and where?
Thanks very much . . .
Brad in TX
01-31-2007 10:50:45
 Re: 1940 Farmall A ?? cable to mag in reply to Brad in WA, 01-30-2007 19:51:31
I just bought a complete mag with the cable attachment and the cable kill switch on ebay for way too much $$$. I've been looking for one for seemingly forever. Did everybody discard those things years ago or what? When it arrives I'd be glad to send some pics of how it's set up.
Roger Mills
01-31-2007 09:01:20
If the mag has a switch on the side it is operated by a push/pull rod. The bracket next to the throttle should be vertical with a small hole in it to support that end of the rod. Check your serial number against the parts breakdown listed at caseih.com. It will tell you what it should have been and show pix of rod, brackets etc.
gene bender
01-31-2007 10:45:51
 Re: 1940 Farmall A ?? cable to mag in reply to Roger Mills, 01-31-2007 09:01:20
The sw is operated by a choke type cable and not a rod.
Bob
01-31-2007 08:17:19
Here's some parts drawings:
Link
Link
http://www.cleancomputes.com/Cub/A%20-%20B/TC-26E%20Parts%20Catalog/Page%2045.jpg
gene bender
01-31-2007 00:00:58
Do you have the sw that mts to the mag? Is there a bracket next to the throttle with a hole in it?
Brad in WA
01-31-2007 06:06:27
 Re: 1940 Farmall A ?? cable to mag in reply to gene bender, 01-31-2007 00:00:58
yes to the right of the throttle. Does the switch mount there?
gene bender
01-31-2007 07:08:03
 Re: 1940 Farmall A ?? cable to mag in reply to Brad in WA, 01-31-2007 06:06:27
no the sw mounts on the mag and the cable runs to the hole by the throttle lever. Now we are talking about a hand crank model arent we? The early ones without starter had a choke type cable running to the slide type sw mounted on the mag is this the cable you mean. Now ones with a starter had a kill sw on the steering post and a insulated wire going to the post on the mag this sw had one post as it grounded out the mag to kill the engine. Do you have the slide sw on the mag?
