block heater
bm3501466
02-04-2007 13:43:54
Has anyone seen any aftermarket block heaters out there for the 193 Continental? I have a 350 and when it gets really cold the manifold heater isn't enough. I would like to just be able to plug it in.
El Toro
02-04-2007 14:11:51
 Re: block heater in reply to bm3501466, 02-04-2007 13:43:54
Here's a web site on tank heaters. Hal
http://www.kimhotstart.com/
Janicholson
02-04-2007 14:04:27
Core plug (improperly called freeze plugs)heaters are a fine addition. I do not know which plug to remove, but they work fine. The next best is a tank heater with hoses to the head, and block drain. A bit uglier, but work well. I do not like radiator hose heaters, they seem to waste heat into the radiator with little going into the block. JimN
