farmall model 656 locked up gears (1972)
a wells
06-24-2007 12:47:52
Need some help, have tractor locked in gear, and can't seem to get it unstuck. Any suggestions
r4etired
06-24-2007 18:05:26
 Re: farmall model 656 locked up gears (1972) in reply to a wells, 06-24-2007 12:47:52
Take off the battery cover,with a long heavy screwdriver you can reach in above the battery and slide the linkage.Most likely it stuck when you were shifting to reverse. If I remember correctly the center one had to be pryed up on mine.When they get worn it is important to shift slow and follow the shift pattern closly.
