You'd THINK So...
A. Bohemian
06-27-2007 12:39:09
...if you extrapolate out the usual air pressure of 15 lbs. or so per square inch given at sea level.
But it doesn't work out that way, for some reason. You ideally want over a hundred pounds per square inch (and no more than a few pounds difference between cylinders). Many of those who post on these boards (myself included) would be thinking SERIOUSLY about a rebuild at much below 90 lbs. per square inch, no matter how well the tractor seemed to be running.
It's one of those things I've never learned the reason for. Maybe someone professionally trained (or just smarter than I) can explain why.
