will not start
boney
07-01-2007 15:12:53
got a farmall m that will not start unless it is pulled battery is full charge when trying to start the wire sometime acts like it is magentics and sometimes it does not could the soleniod be bad or the starter has been converted to 12 volt
jonnny2006
07-01-2007 15:36:47
 Re: will not start in reply to boney, 07-01-2007 15:12:53
I have had the starter "smoke" the starter solonoid and melt wires. It never robbed power away from the coil. Unless your coil gets it's juice right from the solinoid. I have some that get there power from the solonoid and some from the battery. Replace the wires with 6 volt wires even if your using 12 v. as the 6 v is alot thicker and can handel the "load" better. i like to use electrical grease on the connections.
old
07-01-2007 15:23:13
I would pull the starter off and have it checked. If its pulling to many amp it will rob the distubutor of voltage and cause you to have starting problems.
