Wheel weights
300Randy
07-02-2007 08:20:07
I'm looking for some wheel weights for my 300 Utility tractor. Will weights from other years and other models fit? Do you guys know where I should start looking? I live near Blanchardville in Southern Wisconsin. Thanks
J.J. from Afton
07-03-2007 04:35:22
 Re: Wheel weights in reply to 300Randy, 07-02-2007 08:20:07
The rear wheel weights for the row crop tractors will fit anything from the C up to at least the 86 or 88 series. However I do not believe those weoghts will workon the utility tractors cause of the smaller rims with the different shape and different hole patterns for where the weights mount. I may be wrong but I believe you will have to look for weights made specificly for the 300, and possibly the 330 and 350 utility tractors. Still shows and swap meets are probobly your best bet for finding them.
Dave BN
07-02-2007 11:55:20
I think the rear wheel weights from C thru at least 560 are the same. They weigh about 150 lb's or so each. I have two on each rear wheel of my C. I would look in the tractor salvadge yards in your area or go to local auctions and old engine shows. Going price in Michigan is about $100 per pair. Dave
