May have H gear noise figured out
Bob Kerr
07-05-2007 18:22:58
Pulled off the belt pully today and looked for the source of the noise. I think I may have the gear noise in the H figure out. The spacer in between the Main input gear bearings that was missing and is still missing because it wasn't there when I took it apart may be the culpret. with the tranny open I reached inside and pushed the gear rearward as I turned it and the noise quieted down. I wish I had something I could push the gear back with and run the engine to see if it works, but could end breaking something if it slipped, teeth both gear and mine! The new parts will be here tomorrow so I will tear into it more. We had a storm come through today and stop my progress. Big puddle under tractor again.
NDS
07-06-2007 05:54:30
 Re: May have H gear noise figured out in reply to Bob Kerr, 07-05-2007 18:22:58
My Super M had slight noise when running in neutral but since everything else in transmission seemed OK I just ignored it. Went out one cold morning and started tractor and all kind of popping, knocking and grinding started, found out balls had came out of input shaft pilot bearing and cold thick oil picked them up carried them into gears and trashed the transmission. Quess the moral of this storyis a stich in time saves nine or however that old saying went.
LinemanFarmer
07-05-2007 18:40:45
That must be common with the H's, my H has some kinda gear noise coming from up there.
Derek
Bob Kerr
07-05-2007 18:45:19
 Re: May have H gear noise figured out in reply to LinemanFarmer, 07-05-2007 18:40:45
I think it is common. I was told by a guy who lives down the road (who worked for an IH dealer 40 years ago) they were putting in the front trans bearings a lot even back then. Might be a good idea to check your M while it is apart, by the way, how is that going?
LinemanFarmer
07-05-2007 19:40:12
 Re: May have H gear noise figured out in reply to Bob Kerr, 07-05-2007 18:45:19
The M is ready for the new parts as far as I know. And by golly your idea of the dremel and screwdriver with that sheard off bolt was perfect. Like it was meant to be. But I'm hopeing my parts will be here tomarrow and thats what I'll be doing unless I get called out for outages.
Bob Kerr
07-05-2007 20:15:37
 Re: May have H gear noise figured out in reply to LinemanFarmer, 07-05-2007 19:40:12
Glad to hear that worked! I come up with a good one once in a while, hehehehe! Sounds like we will both be in the belly of the beasts tomorrow. If you send me an email I will send you my phone number incase you get stuck on anything just give me a call since my hands will be too greasy to type. I will be gone in the AM to go get the parts. Good luck tomorrow!
JFAVOR
07-05-2007 18:28:21
Bob, I'm following your progress as I'll have to tackle mine sooner or later. Want to wait until summer is over. Keep us posted. Thanks Jim F.
Bob Kerr
07-05-2007 20:19:12
 Re: May have H gear noise figured out in reply to JFAVOR, 07-05-2007 18:28:21
Will do Jim, and I hope I have good news tomorrow!
