826 moving the rear wheels in.
Bradford
07-05-2007 18:57:10
My 826 has the rear wheels about 10 inches out on the axles.
What's the best way to slide 'em in?
I am guessing jack up one side get the four bolts loose, clean and lube up the axles and push. And tricks? I know them 34's are heavy!
Nat 2
07-06-2007 05:17:12
 Re: 826 moving the rear wheels in. in reply to Bradford, 07-05-2007 18:57:10
To me, lubing up the axles would be BAD. Wouldn't the grease tend to compromise the clamp's grip on the axle? I can see cleaning them, but IMHO, NO LUBE.
With the wedgelocks, work smarter, not harder. You need a level, solid surface, a 20 ton bottle jack, and plenty of heavy blocking. Securely jack up one side of the tractor. Use the tool that looks like two horseshoes connected at the U-end by long bolts to break the wedgelocks loose. Without the tool, don't even bother trying because you'll never get both wedges to come loose. Once the wedgelocks pop free, rotate the wheel so the keyway is up and the wedgelock is on the bottom. Remove the wedgelock from the wheel.
Now, you can gently lower the tractor a little so the axle comes away from the wheel just a smidge. Tip the wheel in the direction you want to go, then jack the tractor back up. Congratulations, you've just moved the wheel with no grunting, prying, wailing, gnashing of teeth, hernias, broken bones, pulled muscles, chains, bars, dirty tricks, death, or grease on the axle.
Repeat the process of lowering, tipping, raising until the wheel is where you want it. The more you lower the tractor, the further you can move it per cycle.
Allan In NE
07-06-2007 05:23:53
 Re: 826 moving the rear wheels in. in reply to Nat 2, 07-06-2007 05:17:12
Yep,
Up, down and tip. That wheel will "walk" right in to where ya want it.
Allan
Bradford
07-05-2007 21:49:08
I appreciate it!
K.B.-826
07-05-2007 19:09:19
Jack up one side, loosen clamps, clean and lube axle. Run a chain though two of the holes in the wheel, use holes at approx. 10 and 2 o'clock position. Run chain around the base of the fender and hook tightly. Release park lock and rotate the wheel/tire rearward by hand. SHOULD pull right in. May have to reposition your chain several times.
RustyFarmall
07-06-2007 04:35:12
 Re: 826 moving the rear wheels in. in reply to K.B.-826, 07-05-2007 19:09:19
If the 826 has those those wedge lock axle clamps you will need the special tool to get it done.
