Note for: M. Rad
agpilot
07-15-2007 17:30:25
Hello M. Rad. Back on May26 you posted a note asking about best RPM for your Farmall M in doing some lite work and several of us replyed. Cedric mentioned his Blue ribbom manual that had HP and torque curves after I mentioned my using engine data for piston powered aircraft(non turbo) in selection power sttings to get a desired result somewhat like you were asking. I haven't been on this forum since your 5-26-07 note but I just saw an interesting group test results of a Farmall cub DYNO test that a bunch of fellas did. They posted their results of many tractors tested on a dyno. After 50 years the factory intended results were a little hard to get. But it is interesting to see the attempt to make a valid understanding of just what kind of power vs RPM that each tractor had. Here is the link and I hope it works. Click the charts to get larger view... Link-->http://s102.photobucket.com/albums/m105/andrewspivey/Dyno%20results%20-%20Cubfest%202007/ Hope this is interesting for you and others as well... Nothing like using a dyno. They did not have fuel used at each test point and that would be more inline with what you were asking about 4 an "M" engine... Quite a difference in engines but at least its in the Farmall family... agpilot
