300U PTO hand lever
Brian K
07-15-2007 18:50:03
I finally had time to really determine why the PTO is out of whack. The lever is loose. The woodruff key hole and slot are worn out, and a new key doesn't make things tight enough. What solutions have worked for you? I was thinking about drilling straitght through the whole works and punching in a roll pin, or something like that, but I haven't decided yet. Your thoughts would be appreciated.
Brian in Duluth MN
Wardner
07-15-2007 19:16:03
 Re: 300U PTO hand lever in reply to Brian K, 07-15-2007 18:50:03
There are some epoxy products that repair keyways. Check with Grainger, MSC, or McMaster-Carr on the web.
Janicholson
07-15-2007 18:56:14
Our 350U also had that issue. We used a de=remel tool and ground the woodruf key hole for the next size larger. our groove was ok, so we carefully ground the key narrow to fit the old slot. We also used locktite sleeve and braring retainer fluid on it when assembled (Locktite 64000) It is solid now. Grease is important on the lever. and a penetrating lube like triflow on the links. JimN
