IH 350 utility v. 354
BK
02-10-2000 11:32:21
You all filled me in a few weeks ago on some specs for an IH 350 utility. I just ran across a 1973 IH 354 gas.
Is there any significant difference between the 350 and the 354?
Thanks for your help.
Bob
BK
02-11-2000 08:41:38
 Re: IH 350 utility v. 354 in reply to BK, 02-10-2000 11:32:21
Gentlemen:
Thanks very much for your help.
Bob
SuperCMORE
02-10-2000 22:24:12
I'm not sure, but I think a 350 utility could drag 2 354's backwards..There is significant differences in size...SuperCMORE
Phil Auten
02-10-2000 11:53:21
BK,
Although I can't tell you much about the 354, the 350 and 354 are completely different tractors.
The 350 was only made form 1956-1958. The 354 is obviously almost 20 years newer.
Phil
Harold H
02-10-2000 18:24:00
 Re: Re: IH 350 utility v. 354 in reply to Phil Auten, 02-10-2000 11:53:21
I'M NOT SURE but I THINK the I-354 is a continuation of the B-275, B-414, I-424 etc. line of tractors.
Harold H
Sid Miller
02-10-2000 12:18:29
Phil, I happen to own both of these tractors.They are both solid,reliable tractors.However, the 354 is roughly 15 years newer and easier to find parts for.Here in North Carolina, a good 350 will run from 1500 to 1800.A 354 willrun about 2000 to 3000.If you need other information I can help you.
Don H.
02-10-2000 15:35:06
 Re: Re: Re: IH 350 utility v. 354 in reply to Sid Miller, 02-10-2000 12:18:29
Although I don't have any personal experience with a 354, it's my impression they are significantly less powerful than a 350. That may not make any difference so the greater availablility of parts could make the 354 a more attractive option. I don't know about hp ratings but I'd be surprised if a 354 could pull a 3 bottom plow, while a 350 readily handles one.
