Farmall A front tires
Brian
02-10-2000 13:40:36
Heres an idea The front tire rims and tires were shot on my A, one day I was looking at the 15" dummy spare in my car and it looked like it would fit if the centre was cut out. I went to a junk yard and bought 2 spare tires for $20 and took the centres out of them . they bolted right on, May not be original but they work. The ony problem I had was that where they were tubeless I have to run a high air pressure too keep them from leaking down.
p
02-11-2000 13:37:08
 Re: Farmall A front tires in reply to Brian, 02-10-2000 13:40:36
as a cheap turf tire on our cubs we us trailer tires as the fronts. They work great and have lasted for years. we also use tubes.
Chris
02-11-2000 10:05:27
One time we made a wheel an' tire outta wood. It was not quite round, so the front of the tractor went up and down. Some people made fun, but we liked it.
moboy
02-11-2000 04:47:53
when the front rim on my b rusted away we took a rim from a volkswagon bug and welded the old lugs to it, worked like a charm and looks original.
Bob
02-10-2000 13:54:33
they won't grip snow or loose dirt like a
three rib tractor tire I tryed
Kendall
02-10-2000 13:50:57
Sounds like your powers of observation are working good.
I've heard of running a tube in tubless tires. Can you try it?
kimk
02-10-2000 17:35:47
 Re: Re: Farmall A front tires in reply to Kendall, 02-10-2000 13:50:57
Tubes in a tubeless tire? Yup I used to do it on my FJ 40 Landcruiser. My tire man tells me that if the valve hole in the rim is round then tubes work just fine, but they do not work if the hole is oval. I believe him.
