Out-a-round
Bill
02-10-2000 14:32:25
Have the pistons out of a early M they all mike at
about .008 - .009 out of round. One is at .011 is this to far gone? They cleaned up and look good. Tractor is only used for light duty. Thanks
jakee
02-11-2000 12:58:38
 Re: out-a-round in reply to Bill , 02-10-2000 14:32:25
most good ring companies will show the ckecking clerance for there rings and ring land area.
Bill B
02-10-2000 18:39:33
As Jakee said, they were never round from new. Look at the skirts and see how much scuffing there is. More importantly, clean the ring grooves thorougly and inspect the ring lands to see that they are not worn. As the ring wears, it fits on less and less of the ring land of the piston, and begins to wear that surface. If it is worn much, installing a new set of rings will not work good, since the rings will only be supported at the very edge of the inside circumference of the ring, and will flex with each stroke, wearing them quickly. Check by placing the ring into the ring land where it belongs, without installing it on the piston (edge to edge) check to see the gap between the ring and the ring land. There should not be much gap. You can hold the piston up to the light and sight along the edge of the piston to see if the ring lands are tapered. I wish I could draw you a picture, since this explanation may not make much sense.
If there is a lot of slop in the fit of the ring in the ring groove because the ring land is worn, the new pistons would be a good idea.
HR
02-11-2000 08:50:30
 Re: Re: out-a-round in reply to Bill B, 02-10-2000 18:39:33
Bill B: Very good post. Those ring grooves are a key area of consern and both the ring & groove have to be in specs or forget it.....harvey
jakee
02-10-2000 15:44:16
pistons are not round there ground that way is called cam grinding.
