424 PTO problem
Bobinvt
07-28-2007 19:08:29
I own a 1966 424 IH the PTO does not stay in Gear when shifted in, It sometime stay when not under a load, but if I start cutting again it pops out of gear. I there any adjustment, I don"t see any? Is it a hard repair if there is no adjustment. Thanks for your help. Bob
Bernard le mécano
07-29-2007 08:53:23
 Re: 424 PTO problem in reply to Bobinvt, 07-28-2007 19:08:29
Hi Bob, it have a bushing where the dog engage. The bushing aling the two PTO shafts, when the bushing is worn the dog don't stay engaged.To change the bushing, drain all the transmission oil, remove the PTO lever, the rear PTO shaft, by the cover to access the clutch, remove the large snap-ring, the cap then the snap-ring on the PTO shaft, remove the next cover, push the PTO shaft then remove the snap-ring next to the gear. Push the shaft all the way to the rear hole. Change the bushing and check for wear on the shaft, machined if so . Bernard le mécano Québec Canada
Bobin vt
07-29-2007 18:20:57
 Re: 424 PTO problem, Thanks for the help in reply to Bernard le mécano, 07-29-2007 08:53:23
Thanks for the help, it give me a direction to head in, At least a don't have to split the beast. have a good day Bob
IH2444
07-29-2007 00:29:23
If it is not a bent shifter arm causing it not to go all the way in geat, you will have to remove the lift box under the seat to replace the engagement dogs down in the front of the rearend.
BobinVt
07-29-2007 07:23:36
 Re: 424 PTO problem in reply to IH2444, 07-29-2007 00:29:23
Hi Again, I looked under the seat ands found a small cover 9 1/2 x 6 and took it off and I can't see much because its filled with oil, But I also noticed there is a larger cover over the whole rear end, Is that the cover you are talking about? thanks again, Bob
BobinVt
07-29-2007 05:30:07
Thanks for that Info, The shifter does rest up against the brake cover and the rolled pin that connect it to the shaft looks OK But I will check it out closer, And I am not sure what to look for as far as the Engagement Dogs, What do they look like. Thanks for your Help. Bob
