Listen
A. Bohemian
08-08-2007 18:38:42
Sounds like you've been cranking it a lot, right? If you had a sticking valve(s), you probably should have heard something like:
''uh-uh-uh-whoosh!-uh-uh-uh-whoosh!''
If you have a hand crank, now is the time to use it. You can ''feel'' the compression pretty well with a hand crank.
Or, check the valve clearances. Or, do a compression check.
But I'll bet you know or can guess what kind of valve failure might cause the flame coming out of the carb.
TroyC
08-08-2007 19:49:30
 Re: Listen in reply to A. Bohemian, 08-08-2007 18:38:42
It does sounds like that.
I don't have a hand crank yet, but ordered one last week. (should be in tomorrow)
I haven't done the compression check yet. I should do that before pulling the valve cover.
It certainly sounds like it should be running. I've spent close to 2 weeks workin with it.
Brand new starter, battery cables, starter switch...
I'll try the compression test tomorrow and let you all know.
