H Troubles
Barnaby
12-10-1998 10:18:34
I am working on a 1945 H. Its running. Unfortunately, when I try to go uphill or put it under any load, it goes fine for a while and then sputters and dies like it's out of gas. Adjusting the carbuerator screws seems to have little effect.
I have plenty of gas in the tank. Gas runs freely through the gas line. Is this some sort of carb trouble or am I looking in the wrong place.
If its a gummed up carb, what should I do?
Bob Almstrom
12-10-1998 15:04:08
 Re: H Troubles in reply to Barnaby, 12-10-1998 10:18:34
I would take the screen out of the carb, and see if it has dirt in it. There should be one just under the 90 degree elbow. If not you probably have a dirty carb, or a float sticking.
Bob
Bob Almstrom
12-10-1998 15:03:35
Bob
Ryan Free
12-24-1998 10:31:52
 Re: Re: H Troubles in reply to Bob Almstrom, 12-10-1998 15:03:35
I have 3 H's.1 being a '45. I think that your problem is that you need to have your carb. rebuilt. If your gas line was anything like mine, all it is is a car/truck brake line that you can fine at NAPA.
