international 2500a run-on
Bob Brown
08-22-2007 08:28:05
I purchased a well used IH industrial 454 tractor from a local municipality, hydrostatic trans, (also sold as the 2500A?) and am using it on our small farm, mostly for haying, light field work.
Starting was a problem, remedied by an electronic ignition system replacing the old worn out distributer innards.
My problem now is: Turning off the key means listenenig for 45 to 60 seconds, (more on a hot day) of the poor old girl trying to shut down. It CAN'T be good for her?!?
Is there a fix to get her to stop running after a couple hours work?
Janicholson
08-22-2007 15:31:59
 Re: international 2500a run-on in reply to Bob Brown, 08-22-2007 08:28:05
A slower Idle speed will help as will letting it idle for a bit, if the idle can be set low enough that it at or near 450rpm, it will shut off more readily. JimN
NawlensGator
08-22-2007 08:35:41
I turn off the gas under the tank and let them stall from lack of gas before turning the key off.
Allan In NE
08-22-2007 08:31:49
Slow the idle down and/or close the throttle when shutting down.
Allan
