Char Lynn ps pumps no longer made???????????
RBTXS
08-22-2007 18:24:37
I have been told by 2 different companies that Char Lynn pumps and related equipment are no longer made. (The factory was closed.) Is there any other place making pumps to replace a Char Lynn pump? I don't want to go the Belean route if I can avoid it. Also does anyone know where a Char Lynn pump is for sale?
Bob
08-22-2007 20:46:38
 PUMP or torque generator? in reply to RBTXS, 08-22-2007 18:24:37
Are you looking for a pump/reservoir, or the "torque generator"?
Andy Motteberg
08-22-2007 20:50:45
 Re: Char Lynn ps pumps no longer made??????????? in reply to Andy Motteberg, 08-22-2007 20:12:06
Sorry, when I read Bob's post, I meant to say torque generator, not pump.
Bob
08-22-2007 21:12:05
 Re: Char Lynn ps pumps no longer made??????????? in reply to Andy Motteberg, 08-22-2007 20:50:45
The torque generators, for sure are still being made.
Punch link below, and scroll down a ways to see the various torque generators in the current product lineup.
Al L. in Wisc.
08-23-2007 08:46:44
 Re: Char Lynn ps pumps no longer made??????????? in reply to Bob, 08-22-2007 21:12:05
Bob, or anyone else, do you know what item on the Easton site would be used for a Farmall 340 with factory utility wide front? I would need the works well, the tractor does have the live pto - I want to use the tractor with an IH 2001 loader. Thanks in advance. sign me, GREEN AT THIS.
Allan In NE
08-22-2007 19:30:40
 Re: Char Lynn ps pumps no longer made??????????? in reply to RBTXS, 08-22-2007 18:24:37
The whole schmear is now handled by Eaton Hydraulics. Replacements are not a problem.
Allan
RustyFarmall
08-23-2007 04:35:53
 Re: Char Lynn ps pumps no longer made??????????? in reply to Allan In NE, 08-22-2007 19:30:40
Exactly. You can even get the bracket that mounts the steering motor for an M or an H brand new.
triplerange
08-22-2007 19:26:51
Guys, Look into Parker-Hanifin. They are a big hydraulics manufacturer. For some reason I had it in my mind that they bought out CharLynn. Could be just my imagination, but they supply a heck of a lot of industrial and mobile hydraulic parts to different manufacturers.
georgeky
08-22-2007 18:37:03
Everything except the pump is still available. OEM has parts and Brad Marshall can get parts as well. If your tractor already has live hydraulics it doesn't need the pump. Only a priority flow valve and steering motor. OEM 1-800-283-2122. Brad at 1-888-824-0544. I spoke to Brad just a few days ago and ne can get the valve and motor.
CityBoy-McCoy
08-22-2007 18:29:26
From what I am told, that is correct; they are no longer made. I see them for sale quite often on ebay, however. mike durhan
