carb
560guy
08-25-2007 20:30:44
I need to put a carb kit in my 1963 560G, Where is the best place to purchase one? From C-IH? or aftermarket?
Johnny D
08-26-2007 11:30:41
 Re: carb in reply to 560guy, 08-25-2007 20:30:44
You also might want to replace the float which can cost arount $15. I had mine rebuild on my C and the old fellow told me to get a new float if I wanted to make sure that I had no worries. By the way, a good carb guy can overhaul it pretty easily so you should get it done for a reasonable amount. For example, he just charged me $25 labor to fix it. Its not worth me tackling for that.
RustyFarmall
08-26-2007 05:29:53
Case-IH will want right at $90 for theirs. Aftermarket will be around $32, and every bit as good. If all you need is a set of gaskets and a new needle valve and seat, the cost goes down to under $10.
