606/2606 steering wheel removal
bc
09-04-2007 00:52:14
Hi, I have a leaking power steering hand pump assembly that is leaking just under the steering wheel. I need to replace whatever seals are in it.
What I have looking up at me is a threaded steering wheel shaft with some kind of a round nut above the steering wheel. (the picture in the book shows a regular nut you can put a wrench on) Does this pull off or does it screw off with a pipe wrency? If it screws off, how do you back it up? Thanks.
